removing d16z6 question, harness and sensor?
I'm currently removing my d16z6 engine from my SI hatch, I think I've got almost everything unhooked, I'll be dropping it out the bottom. The wiring harness seems to go from one shock tower to the other, right under the intake manifold. It goes between the engine and the manifold bracket, and I don't see any connections where it unplugs, so when I drop out the engine, the harness would still be going through it.. I don't think its normal to remove the bracket? Do I unplug the harness way back, and pull it and all its wires that come off it all through to the driver side? Or maybe this section of harness normally comes out with the engine.. Sorry, this is my first engine swap
You can see the harness going through between the bracket and the engine in the 2 first pictures.
Also you can see the wire in the second pic, just above where the oil filter goes. how does this come out? i didn't spend much time with it, but may as well ask while i'm here..
ill worry about that sensor later
ill just keep trying
