Egs come with stock tweeters?
Thu May 10, 2012 1:25 am
by couch_c
I think I've seen some but I'm not sure if it's aftermarket or stock, If they do which models come with them?
Thu May 10, 2012 3:04 am
by rak511
If your talking about the tweeters on the door panels, just to confirm my si hatch has them.
Thu May 10, 2012 3:12 am
by couch_c
rak511 wrote:If your talking about the tweeters on the door panels, just to confirm my si hatch has them.
What year is your si and is your si powered?
Thu May 10, 2012 4:59 am
by egbeegee
Im pretty sure they came stock in si and maybe ex models?
Thu May 10, 2012 5:53 pm
by HungRealLow21
Edit :yea they come stock on the ex coupe,very rare on the sedan and some si hatches!
Thu May 10, 2012 5:57 pm
by couch_c
My si hatch didn't come with tweeters, the door panel doesn't even have cutouts for tweeters, the only thing powered in the car was the moonroof. I'm just wondering how it's wired bc I want to install some tweeters soon.
Thu May 10, 2012 6:19 pm
by asianrob
some EX coupes had them.
Si's are a little harder to find with them
sedans rarely seem them. its like a needle in a hay stack. i've only seen one sedan that had them. and they sit different then the coupes/ hatches
but either way you can just drill the hole out and put them in there. i've done it plenty of times its not hard..
i think the tweeters were AR ( or something like i have to look at my coupe)
Thu May 10, 2012 6:24 pm
by couch_c
I've never had tweeters so I'm not sure the correct way to wire them, I was thinking it was only just tapping into the speaker wires since the head unit only has Lfront speaker and Rfront speaker and doesn't have one for tweeters, and I don't want to use an external amp for them either.
Thu May 10, 2012 8:21 pm
by Civic_HatchSI
egbeegee wrote:Im pretty sure they came stock in si and maybe ex models?
my si never came with them
Fri May 11, 2012 10:00 am
by asianrob
yea its going to be harder to find an SI that had them. it was just mostly EX coupes that had them
Mon May 14, 2012 4:30 pm
by 93sihatchguy
I have the oem tweeters in mine, but I did the power window/door lock conversion. I also changed the stock tweeters to Infinity Kappa Perfect tweeters. The OEM tweeters were Acoustic Research
Tue May 15, 2012 2:36 am
by elrompetoto
All ex coup brand then and all eg hatch and coupes have a spot with an out line where u can add them I have done it a bunch of times take ur door panel off and around the top u will c a round out line where u cut 2 instal the tweeters
