- Sat May 26, 2012 2:33 am
#306264
My 92 civic vx will not crank. I have a b20b/b18c1 head. The other day my fuel pump would not come on so i started looking into the problem. here is what i have done so far.
-Jumped the Main relay from 5 & 7 and tested for voltage at the fuel pump connecotr and the connector that attaches to fuel pump. Tested good
-Tested my main relay from the haynes manual and it tested good.
-Continuity check of all wires attaching to main relay. All wires good.
-i wired the fuel pump straight from battery and it worked.
- New fuel pump same issue. have to wire from battery
-Checked fuses 18, 24, & 31 all good none blown
As of now i have it wired into option 4 on the fuse box and my car cranks as long as i have the headlight on.
the main problem is that the fuel pump will not come on when i have the connecter plugged in. everything else works great. Car cranks with no issue as long as i am running straight from battery to fuel pump.
Any help to why my fuel pump is not turning on with its connector would be greatly appreciated.
