- Sat May 26, 2012 8:31 pm
#306323
i was wondering what id have to do to line up my front end nice and clean, thee spaces in some places begween corner lights and headligts.
- Sat May 26, 2012 11:21 pm
#306339
do u have aftermarket headlights or OEM headlights
- Sun May 27, 2012 12:02 am
#306343
take off ur front bumber and look at the front support frame, might be abit crooked
- Sun May 27, 2012 3:28 am
#306360
probably this
gtstripes wrote:take off ur front bumber and look at the front support frame, might be abit crooked
probably this
- Sun May 27, 2012 3:32 am
#306362
And if it is?
- Sun May 27, 2012 7:52 am
#306372
well if it is.. then, thats the problem? lol
- Sun May 27, 2012 3:55 pm
#306383
hammer time
HungRealLow21 wrote:And if it is?
hammer time
- Sun May 27, 2012 4:14 pm
#306386
du dudududu cant touch this lmao
TrailerTrash wrote:HungRealLow21 wrote:And if it is?
hammer time
- Sun May 27, 2012 7:20 pm
#306405
Can you post a picture?
Check out my build thread:
http://civic-eg.com/viewtopic.php?t=22966
- Tue Jun 19, 2012 4:21 am
#308710
Not sure if its the same or not but I had a Gap under my headlights even though I tried several times to readjust my front bumper cover and mounting on headlights.
I found out there is this little metal pieces that mounts on top of each side of the bumper/ crash bar by 2 bolts that helps support the bumper flush up under the headlight. Not sure if yours has it or not or if it helps but there is also a foam reenforcement piece that mounts in between the front bumper and the bumper cover
- Wed Jun 20, 2012 4:35 am
#308813
good find
mADmAN wrote:a DIY fix
http://honda-eg6.blogspot.com/search?q=bumper
good find
EG8 Build: http://civic-eg.com/viewtopic.php?t=20985&highlight=
EK Build: http://civic-eg.com/viewtopic.php?t=257 ... highlight= SOLD
#10 of The Civic-EG.com Ferio Squad
- Thu Jun 21, 2012 3:35 pm
#308979
Its just a quick fix, not a perfect job ;p
I'm missing the front bumper beam and absorber which might help holding up the bumper better.
- Sun Jun 24, 2012 2:48 pm
#309235
Great info guys
OP, if you mean between the headlights and the corner lens, maybe its a broken slot that the corner lens slides into the headlight. The lens should sort of interlock with the side of the headlight, and then 2 little nubs on the fender side of the lens go into the fender. They seem to break off easily too
My EG Hatch Build
http://civic-eg.com/viewtopic.php?t=22106
1993 Civic SI Hatch - project!
1999 Acura EL - winter beater!
