- Thu May 31, 2012 10:06 pm
#306841
i have a b18b1 in my 92 civic hatch and is in need of a/c, so i need to know the parts that will be need, which bracket, compressor, lines ect do i need thanks all
- Fri Jun 01, 2012 4:47 am
#306877
come on guys, i know i need a b series bracket but what about the ac lines and compressor, do i have to use all b series?
- Fri Jun 01, 2012 5:34 am
#306882
My write up
http://clubeg6.com/forum/viewtopic.php?f=9&t=27978
First off It's really easy to retain the all the stock AC components in your 92-95 Civic HB with a any swaped B-series motor.
If you have all your stock AC equipment then all you need is a AC bracket from a Del Sol Vtec or a CRV and a AC belt from a 93 GSR. The brackets you can buy at a dealership, they cost around $140 if I remeber correctly. When you get the AC bracket don't forget the belt tensioner with the bolt. Mine didn't come with it when I ordered mine from Ebay. I believe they don't come with the bracket but you can ask whoever your buying it from.
Here are the Part Numbers:
38930-P7J-000 CRV Bracket
38930-P54-000 Del Sol Bracket
1. First off all the stock AC components need to be in your car. You don't need an integra compressor, Integra lines, or Condensor to make this work, but it's possible with integra parts but requires custom work.
2.With the B-series motor in the car install the AC bracket of your choice onto the motor. Your going to need the bolts off of your stock motor that holds the bracket and the compressor onto the bracket. All the bolts should line up.
3.Install the compressor onto the bracket. All four holes should line up. If the bolts are dirty I suggest you clean them and the holes they are going in.
4. Install the High and Low side pressure lines onto the compressor. Don't forget to use new O-rings and apply oil to them before you put on the lines. If you didn't take off the compressor and your system ain't open, then you don't need to install the lines since its already installed.
5.Now test fit the AC belt from a 93 GSR. If its too long you can always go back a to the place like Autozone, Pepboys, or Advance Auto Parts and ask for a shorter one. I suggest just bringing your car with the mounted compressor so you won't waste gas and test fit there.
6. Now charge your system if your system was open. If you have any questions on charging it you can post here and I'll answer your questions.
When I got my car the AC system was JACKED :eek: So I pretty much installed a whole AC system from a donor vehicle.
Here is a vid of my AC working: http://www.youtube.com/watch?v=LF9yWzJ3lko
This was at Idle (1000rpm), fan setting at 2, ambient air temp at 85F, and with 50% humidity
94' civic si
JDM B16A w/AC
JDM B16A w/AC
- Fri Jun 01, 2012 11:17 am
#306897
^^ nice write up
http://civic-eg.com/viewtopic.php?t=17296
My for sale thread check it out!
http://www.civic-eg.com/viewtopic.php?t=25828
#3 CivicEG.com Ferio Squad
- Fri Jun 01, 2012 4:11 pm
#306923
thanks bro!
I hope it helps out the OP
familyEGuy23 wrote:^^ nice write up
thanks bro!
94' civic si
JDM B16A w/AC
JDM B16A w/AC
