- Thu Jun 21, 2012 1:40 pm
#308971
Ill Try to make this short and detailed. Wife took car to work car not work anymore lol.
The car powers up IE lights, fuel pump all turns on but it wont crank. I checked all fuses and the relays seems to be clicking over. I tried jumping the car thinking maybe the battery weak but no luck. Starter wont click so I am guess somwhere between the ignition and the starter i have a problem. Any suggestions? Thanks
Still no luck i replace the ignition switch and still having the same problem. I doubled checked all the grounds, fuses and relays and still nothing. The neutral saftey switch was check and and jumped. I checked it and made sure all the connections, fuses and relays are getting power but everything checks out fine. I can hear the 12v relay in the fuse box in the engine bay clicking over but nothing after that. But the second i jump the starter it starts right up
