- Sun Sep 16, 2012 8:01 am
#315772
I searched everywhere for lists of additional parts that were needed to install a B18C Type R engine and transmission.
As soon as I find the information needed Im going to buy the engine.
I plan to buy this engine and transmission: http://www.jdmtigerjapanese.com/honda-a ... on-96.html
These are my questions:
1. What other parts will I need?
2. Will I need to purchase the additional equipment they have listed?( The ECU, Wiring Harness, and engine mount)
3. Is this engine and transmission ready to drop in without any fabrication?
4. Will I need to have the car tuned? Do I have to buy a hondata 300 and a AEM wideband? ( I dont want to buy these, my car is not for racing, just a daily driver car)
5. What other parts should I replace while I have the engine and transmission already out before it gets installed. I can only think of a few: B18C water pump, timing belt, spark plugs, clutch kit. (maybe new fuel injectors yes/no?)
4. Will the B18C-R axles fit? Or do I need to buy some hasport b-series axles : http://passwordjdm.com/Hasport-B-Series ... 2C472.aspx
5. Will the B18C-R shift linkage fit? Or do i need to buy a hasport shift linkage : http://www.jhpusa.com/store/pc/viewPrd. ... egory=1573
6. The engine i'm buying comes with a powersteering pump. I would like to have powersteering, so could I just go look for all of the other power steering parts off a GSR integra and hook it up? If I am not able to get powersteering then would all I have to is take off the power steering pump?
A performance shop will install the engine and transmission for about $650.
Since my uncle owns a a autobody shop and a junk yard, Im going to have my friend change out the clutch and spark plugs and then send over the engine and transmission to the installation shop.
So I hope this doesnt go over $7,000.
So far I spent
$1,500 92 vx civic
Future:
$4,220 engine and transmission (with tax)
$250 clutch
$150 water pump
$50 Timing belt
$800 installation
and more for all the other parts I find out I will need
I dont want to add or spend anything on modds that increases hp, I just want this to be like a daily driver 2006 honda civic SI/etc
So far I spent
$1,500 92 vx civic
Future:
$250 clutch
$150 water pump
$50 Timing belt
$800 installation
