What I have done to change the light combo switch was:
-Remove 3 Phillips screws from lower column cover
-Pull apart both upper and lower column cover
-Turn the steering wheel so you can have access to two screw holding the combo switch and remove them
-Unplug the connectors behind the combo switch
Install on reverse procedure
, only to be recovered with wheels missing, mirror missing and headlight switch broken. I am glad to have the car back with engine untouched. I will find another switch, but I don't know how to install it. Any way to do this?
