- Fri Mar 14, 2014 9:25 pm
#343395
So long story short I've been fighting this ignorant idle surge for a while now and also i cannot get my base ignition timing set as well. I can get it close by advancing the distributor all the way but it's obviously not correct so i got to checking the valve timing and moved a tooth on the cam gear which took it way too far. So heres the question I've been racking my brain on and going back and forth.
Moving a tooth on the cam gear and moving a tooth on the crank gear would result in different degrees of advance/retard as if the 2:1 ratio correct? Not that what I'm doing is the correct thing to do just a technical question i can't figure the logic out on.[/code]
