- Wed Mar 26, 2014 8:22 pm
#343750
Ahhhh! Hows things lads, alright so the engine went in without a problem, i put the obd1 intake on the obd2 block and it all looks good all the plugs are matching up and i have everything done i need done, now, i put the battery in and the fuel pump started suckin but the starter wouldnt spin or even try the fuse box under the bonnet keeps clickin like its a relay i changed all the relays and the same thing happened just fuel pump suckin injection spitting but no starter, so i changed the starter as i had left the starter that came from ek or obd2 engine to the obd1 starter and anytime i connected the starterr and tried the ignition again this time just sparks came from the starter so i turned it straight off.... so what should i do? Put the ek starter back on or leave the eg one on? How can i check if the starter is still ok? Cheers for the help on the last post by the way!
If its not jap, its scrap.
