- Tue Jul 01, 2014 10:41 pm
#346904
I need to drill out the spot welds to replace the radiator support. I'm reading that it's about 30 on each side? I see a bunch of them but I can't seem to find a source that shows which ones I'm supposed to remove. I don't want to remove unnecessary spot welds, unless I'm supposed to remove all the spots welds I see on the front. Any ideas? Pictures would be appreciated, thanks in advance.
- Thu Jul 03, 2014 8:44 pm
#346954
It was pretty obvious when I did this on an EF. Pretty sure you remove nearly all of them.
- Thu Jul 03, 2014 9:22 pm
#346958
There is an old build thread on here with pics of the core support removed. Scroll down and take a look. It will give you a better idea. Good luck! I'll be doing this on my black ej6 this summer as well.
http://civic-eg.com/viewtopic.php?t=708 ... 37cea1fd22
- Sat Jul 05, 2014 2:34 am
#346983
Yeah I looked at that a while ago but it's very hard to see where he drilled. I just finished today and managed to remove the radiator support using a spot weld bit. Took about and hour or less.
CopyLifted wrote:There is an old build thread on here with pics of the core support removed. Scroll down and take a look. It will give you a better idea. Good luck! I'll be doing this on my black ej6 this summer as well.
- Sat Jul 05, 2014 2:44 am
#346984
Awesome! Yeah, it does look pretty straight forward. I also have to remove and replace the piece between the support and shock tower on the passenger side. Unfortunately they don't make that as an aftermarket piece.
couch_c wrote:CopyLifted wrote:There is an old build thread on here with pics of the core support removed. Scroll down and take a look. It will give you a better idea. Good luck! I'll be doing this on my black ej6 this summer as well.
- Fri Aug 15, 2014 1:38 pm
#347901
Here is the radiator support I removed. all of the holes are the spot welds that need to be drilled out....
