Newb Help PLEASE
Hey, a Question for you civic know alls please
1992 Civic hatch CX auto, checked the oil yesterday and it was bone dry!!! so i filled her up again and constantly check it. there is no oil stains under the car where i park or at work, i cannot think where its going except being burned off. so what would this mean? i was told "yeah, so your engine is scrap"
im having alot of trouble starting her in the mornings when cold, I think that the batt needs changing, i was told that i could adjust the plugs a little to get a better cold start.
Thanks in advance guys and or gals
Cheers
Mike
Cheers
Mike
.. Your motors piston rings are probably going out and your compression is dying too.... pull out a spark plug and see if its gummed up with carbon or whatnot... and if you know how... do a compression test on your motor.... that willl for surelly tell you about your piston rings .... or valves.. O.o
