Proper launching techniques
Wed Nov 19, 2008 6:38 pm
by OmarG
I think this would be an excellent thing to discuss. Anyone have tips, or rule of thumbs?
Wed Nov 19, 2008 9:23 pm
by LowTEC-Derbo
dont drop the clutch. that will kill your drivetrain
i usually pull the handbrake. release the clutch to near the catchpoint where the car starts to move a little forward, and then slip the clutch off so its a clean launch. I haven't broken axles since I learned this way. I done plenty of 7200rpm launches on slicks like this.
I used to drop the clutch with the rpms at 4-5krpm and it snapped my axle. Course I'm sure on a stock motor, the torque might not be enough to snap it, but better to have a good technique perfected before getting more power.
Wed Nov 19, 2008 11:24 pm
by Method
LowTEC-Derbo wrote:dont drop the clutch. that will kill your drivetrain
once i was taught to use the handbrake for launching it def. cut down on my time.
Thu Nov 20, 2008 3:17 pm
by Method
Tips to getting a "good" reaction time
DO NOT WAIT for the green light to come on.
The yellow ambers will flash 1 at a time .500 seconds apart
When the 3rd amber(yellow) light goes on LAUNCH your car. if you do that you will see a decent reaction time. once you get consistant you can tune yourself from there. perfect reaction at sparta is a .000 if you wait for the green your most likely comming out with a 1.xxx which is terrible
Coles notes Launch your car on the 3rd yellow light NOT the green
Fri Nov 21, 2008 9:55 pm
by sdots
Method wrote:Tips to getting a "good" reaction time
I do the same ^^ however no handbrake, just perfect your clutch bite point.
not so on point so the tranny engages power to the fly, however just before, works a treat for me everytime, haven't been on the strip yet, however on the road it works great. Good tires also help
Sat Nov 22, 2008 3:11 am
by ohDirka
I grew up at the drag strip and was always told to launch o the second yellow light. the reason being is your brain takes a second to put you body into motion. I've had several .00- lights. This is at least what works for ME.
Sun Jan 11, 2009 3:27 am
by TurboHatch
sdots wrote:Method wrote:Tips to getting a "good" reaction time
at the track you will want to use the ebrake to hold you still, reason is if you have a little to much engagement you will move out of the beams and redlight
Mon Jan 12, 2009 12:25 am
by sdots
TurboHatch wrote:sdots wrote:Method wrote:Tips to getting a "good" reaction time
Fri Feb 13, 2009 2:39 am
by JUICE
so you keep your hand on the handbrake as tree is comin down and put it down at instant you leave?? then directly to the shifter for second?? seems like it would be weird not holdin the shifter while launching. guess i never have not held it.. I'm guessing it wouldnt pop out of gear?? ive raced at the strip before and know how to stage and launch and all that but it was in an automatic and i was just "two footin" the pedals launchin like that.. have not done it with a manual tranny yet.
Wed Jul 08, 2009 2:51 pm
by doitpropa
never gone to the track but what about launching in second .. less tire spin one less shift messed around like that on the road nd it was pretty good but i don't have much more than stock power in my b series w/ b16 tranny
Wed Jul 08, 2009 11:55 pm
by Sentry
Unless you're making serious power and are on slicks, I just see second killing your sixty foot time, and thus, your run.
Thu Jul 09, 2009 12:00 am
by JUICE
Sentry wrote:Unless you're making serious power and are on slicks, I just see second killing your sixty foot time, and thus, your run.
x2
it would fall on its face
Fri Jul 23, 2010 2:13 am
by Sabes
ride pretty much all of 1st and ride the clutch for a bit of second as well. Unless you got a short ratio tranny and a good helping of torque, in that case dump in second and keep going
