need help with interior wiring in my ej1
will a 2 door interior wiring harness from a automatic work in a 2 door manual. both cars are 94 civic ex. kinda noob question
https://www.forum.civic-eg.com/
teal_dx wrote:There's going to be some differences you should be aware of:*2
- Auto uses the blue interlock box up under the drivers side dash- you can ignore that box & leave it behind.
- Auto has the harness/plug for the console shifter. The 2 thick wires from this plug should be ran to the clutch safety switch on a manual car.
- There's 2 other wires in that plug (unsure of the colors) that should go to the reverse sensor on a manual transmission car. This will make the reverse lights work.
teal_dx wrote:There's going to be some differences you should be aware of:thanks. good info to know
