- Wed May 13, 2009 5:11 pm
#116654
Classiccarsrule85 wrote:Chance wrote:IMHO you should ALWAYS build your motor because You WILL want more psi
SOHC FTW!!!!
ohhh yea trust me no matter what you will want more power but for right now what i would do is make your own kit.....
Get a hf manifold,cx/vx/std make an adapter plate or get one for probaly a T25 turbo since those are nice small and great for low boost setups and fabricate lol check out homemadeturbo.com
homemade turbo FTMFW!
Made a Home made Turbo kit now. Boost your z6 and get it tuned. Then while you have a fast car, pick up another z6 block/engine. Install Forged Rods and Vitaras. Arp Rod Bolts and Head studs.
You know have a Bottom end good for 600hp or so. When you get a chance swap pull your engine and swap in your built block. Head to your tuned crank up your boost and make some big numbers.
Getting and installing a Turbo cam would also be a good idea while your engine is apart before your retune on more boost.
That was pretty much my plan before I decided to go with Nitrous instead. I was going to make a Turbo-Nitrous Build.(when boosted a 25shot gives about 50hp) Until I got mad at my car and sold it. Still at times I am very tempted to do it on my Sedan as I still have most of the parts needed to do it.
