interesting engine. is it the Philippine version with 127hp?? i'm guessing from the "PI" that's where your from? If so, that's a pretty rowdy Vtec-E motor
EDIT: just saw "your ride" thread, good shit
welcome.
1996-2000 VTi (Phils. & NZ/AUS)
* Displacement : 1,590 cc (97 cu in)
* Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
* Compression : ?:?
* Power : 127 hp (94.7 kW, 129 ps) @ 5800 rpm
* Torque : ? ft·lbf (? kg/m, ? Nm) @ ? rpm
* Valvetrain : SOHC VTEC(4 valves per cylinder)
* Fuel Control : OBD-2 MPFI
* Head Code : P2J
* ECU Code : p2n
* Piston Code : P2MY
