New to the site but not new to Hondas
Hi, the names Stephen and i'm from Rapid City, SD. I currently own a 93 EG hatch that i bought stock in Cali but have changed almost everything on it. I'm big into AutoX and that's what my car is set up for but it is also my DD.
Suspension: Full Integra suspension with 22mm sway bars front and rear, Koni/Ground Control's, ES bushings, ASR subframe brace, OEM front strut tower bar, Integra steering rack (running manual), Skunk2 upper control arms, Skunk2 rear camber adjusters, and PWJDM rear toe adjusters.
Brakes: Redrilled prelude rotors up front 11", Legend calipers, 2002 Si rear rotors 10.5", RSX rear caliper brackets with Integra calipers, Hawk HP+ pads, goodridge brake lines, EF sedan 15/16" master cylinder, and 40/40 proportioning valve.
Engine: B18B1 bottom end with RS Machine 81.5mm PR3 pistons, B16A2 head (stock), polished and fully balanced rotating assembly, ARP rod bolts, ARP head studs, Cometic headgaskter, Hondata intake gasket, AEBS intake manifold, PWJDM "whale penis" intake wrapped with reflective film, ITR throttle body, Hytech replica header SS304 with wrap, Tanabe Medalion Touring exhaust SS304, Vibrant Performance ultra quiet resonator where cat use to be SS304, Lightened GSR flywheel, lightened LS pulley, GSR timing covers, shaved flat black valve cover, B16A oil warmer/cooler, and Golden Eagle LS/Vtec kit.
Transmission: CTR trans (LSD) with LS 5th gear for gas mileage, Fastline Performance shifter, ES shifter bushings, Fastline Performance stainless clutch line, and Driveshaft Shop axles.
Exterior: PWJDM smoked corner lights, TYC black housing headlights, and the rest is stock and in need of paint, haha. Function > Form
Interior: Stripped from behind the front seats and back and EK cluster.
Wow, thats the first time i've made a list of mods before, that took a while, haha. I'm sure i've missed some things to.
