- Fri Sep 23, 2011 10:01 pm
#274057
I have those exact one piece headlights in my sedan too. The light output isn't great AT ALL! When installed, the adjustments are up against the support and it's all angled down toward the road. I had to use some scrap aluminum and rig up the top mounts because all 4 brackets broke when i removed them from the car.
I actually had to take them off the car because there was an air gap in the bottom seal and dirt made its way into the chrome reflector and coated the back of the lense. I was able to pull the 'seal' and separate the housing halves with a screwdriver... I cleaned it out and resealed it with proper black silicon and it doesn't get dirt in it anymore but the output is STILL down on the road instead of where it needs to be. Brights just make two V's patterns so i can see the middle strip on the road, and the side of the road, but it's dark in between.
I'm trashing them after a different set coming. Might just go with a two piece non-diffused clear main housing with amber corners.
