AC/Power steering and B18C1 in EG8? What parts to use? help!
PostPosted: Wed Nov 25, 2009 5:18 am
by jdm_rolex
Do i use my old ac and power steering from d-series, with different mounts from b-series? OR should i use bseries ac and power steering components with b-series mounts?
PostPosted: Wed Nov 25, 2009 6:18 am
by chrono404
You will want to get the mounts off a Del Sol VTEC. You can then reuse your Stock EG A/C pump and Power steering pump.
If you get them from Honda make sure its the VTEC model, which has the b16a3 in it. Not the Si model with the D16z6/d16y8
PostPosted: Wed Nov 25, 2009 4:42 pm
by jdm_rolex
can DC ac and ps mounts be used?
PostPosted: Wed Nov 25, 2009 5:28 pm
by chrono404
jdm_rolex wrote:can DC ac and ps mounts be used?
DC Mounts wont hook up to our EG D series Pumps. Which is why you need to Del Sol VTEC mounts.
PostPosted: Thu Nov 26, 2009 4:19 am
by asianrob
as long as it is P72 (GSR or B16 bracket for power steering it will be ok,) BUT you WILL NEED the integra Power steering Hose! its longer and bigger than D series.
