- Tue Dec 08, 2009 9:45 pm
#160653
Its always recommended that up upgrade the pistons, all internals actually. The engine wasn't designed for boost...yes you can boost it stock. In the long run building your engine for it will benefit you. Especially when you want more boost, which you will after a while.
If boosting stock there is a lot you want to take into consideration.
how many miles are on it? were they hard miles (racing, taking to 7k RPM's alot)? how much boost are you running? is this your DD? looking for any specific numbers?
Also you want to do a compression check too.
My Build
#2 member of "White sedans FTW" club
It will not let you down, its a Honda! Provided by aliens, claimed by Japan!
