Page 1 of 2
speed limiter?
Tue Mar 23, 2010 1:44 pm
by Zaraki89
quick question i have a 93 civic lx and no matter what i do i cant get it to go past 95 mph or 97 on a good downhill, my question is do the civics have a speed limiter in them?
Tue Mar 23, 2010 1:46 pm
by TrailerTrash
your car probably just doesnt have the balls to get it past 97mph.
Tue Mar 23, 2010 1:57 pm
by 99cx
are you maxing out RPM when your trying?
doers it feel like it just cuts out when you hit that speed?
your car may just be in need of a tune up?
Tue Mar 23, 2010 2:23 pm
by Zaraki89
when it gets to 95 it just stops accelerating it feels like it wants to but it just doesnt
Tue Mar 23, 2010 2:31 pm
by forcefedEG
ive never seen one that has, but i know in different tunning programs you can turn the speed limiter off, so it may verywell have one... i have never had a honda with a stock computer have a speed limiter... maybe ive just never been fast enough to hit it, but ive ran well over 120 with cars with stock computers in them
Tue Mar 23, 2010 2:53 pm
by Zaraki89
ok thanks, i know it needs a tune up so ill try that then the tunning programs, also it is an automatic but idk if that would have anything to do with it or not
Tue Mar 23, 2010 2:54 pm
by forcefedEG
Zaraki89 wrote:ok thanks, i know it needs a tune up so ill try that then the tunning programs, also it is an automatic but idk if that would have anything to do with it or not
it may idk, ive never gone over 80 or so in an auto honda lmao
Tue Mar 23, 2010 3:02 pm
by marquisdee1018
I have an auto and have done more than 100 on the track before. You might just need a tune up.
Tue Mar 23, 2010 3:45 pm
by Zaraki89
yea it looks like that might be the problem ill get a tune up an see if that fixes it thanks for the help
Wed Mar 24, 2010 3:49 am
by tigerafro
maybe upgrade some parts? intake, header, exhaust to get you those few extra mph?
Wed Mar 24, 2010 4:43 am
by 92egdxhatch
well the lx comes with a d15b7, not a very good engine for power, add an automatic to that it doesnt equal a high top speed. ive done over 120 in my b7 mated with a cx 5spd.
Wed Mar 24, 2010 6:37 am
by Trang
I was thinking the same thing on the speed limiter. I hit roughly 120 on my d15b non vtec and the gas cut out, felt like the computer shut it off. I still had several thousand more rpms to go too
(on a track of course)
Wed Mar 24, 2010 1:56 pm
by AutoXCivic
IIRC the speed governer is actually set at 112 MPH before it cuts fuel. I'm not sure that our speedos are completely accurate. Could be wrong. Though many factory limiters are set at 112.
I know I got my b7 over 100 with only SRI ... speedo read 110ish again not sure how accurate the speedos are up that high.
Wed Mar 24, 2010 1:58 pm
by Zaraki89
ive put on a aem short ram intake and a cat back exhaust to see if it was a lack in power but it still would only go 95 an it seemed to be harder to get it to do it
Wed Mar 24, 2010 2:03 pm
by AutoXCivic
The SRI isn't doing a whole lot for you ... yes it flows a bit better than stock, but once the engine compartment warms up it's just sucking up a bunch of hot air. The limiting factor is probably your stock exhaust manifold ... you may have opened up the airflow past the cat ... but your choke point is before that, you may want to get a proper header as well to compliment the free flowing exhaust. It's like dumping water through the small end of a funnel ... yeah that back end is huge, but it can only flow as much as will fit through the small bit.
