- Thu Apr 15, 2010 9:15 pm
#188030
this looks cool never saw one before but like to get my hands on 1 4wd civic.
http://www.youtube.com/watch?v=nKWTjad4 ... re=related
- Thu Apr 15, 2010 9:32 pm
#188033
build one! After i boost my d series i wanna buy a civic wagon, Then take the 4wd system out of it then put it in a hatch.
- Fri Apr 16, 2010 3:00 am
#188093
I want to do the same with my hatch but with the front drive shafts removed so it would be rwd and awd when i want it to play in the snow
your car is your story, dont let someone else write the book.
91 s10 (sold)
92 civic si with jdm b16a (Sold) http://civic-eg.com/viewtopic.php?t=13460
99 civic lx (current) viewtopic.php?f=63&t=30348
91 s10 (sold)
- Sat Apr 17, 2010 1:45 am
#188271
I wish I could get one in the US..
- Mon Apr 26, 2010 6:25 am
#190094
http://www.gspeedcorp.com/ the shop is on the west coast tho
DuhQbnSiLo wrote:I wish I could get one in the US..
- Mon Apr 26, 2010 6:29 am
#190096
That is a very easy way to ruin the awd tranny's, They have a clutch in the middle so the rear gets upto 50% of the power when the front axles spins faster then the rear axles.
A Turbo AWD Civic would be killer, The Launches would be insane.
blk92hb wrote:I want to do the same with my hatch but with the front drive shafts removed so it would be rwd and awd when i want it to play in the snow
- Mon Apr 26, 2010 7:40 am
#190109
It's been done. I've seen videos of a turbo'd 4th gen civic that was making 250+ to the wheels, and using the wagon drive train. Those transmissions are the weak point though if I remember correctly
chrono404 wrote:blk92hb wrote:I want to do the same with my hatch but with the front drive shafts removed so it would be rwd and awd when i want it to play in the snow
Straight lines are for sissies.
- Mon May 24, 2010 6:37 pm
#196519
My question is about the CRV drivetrain and if it able to provide more balance in power distrubution as well as the strength to withstand hp numbers up into the 300's? I am pretty serious about having an EG Civic that can compete with the likes of AWD monsters with it's light weight and impressive launches. Does anyone have any info about this type of swap??
Performance, and performance alone, dictates the predator in any food chain!
- Sun Jun 06, 2010 10:26 am
#198858
Theres a 4wd civic local to me. Its white, rides high on some white alloy wheels and looks like a rally car.
I've just been reading my manual and the 4WD models had 6 speed manuals. That is, with an ultra low gear for ice and crap. The Autos also had a sport mode that changed the shift points to be better or something.
There was also a bolt kinda thing under the hood that disabled the rear wheels for towing. So you could have some fwd oversteer fun if you wanted to?
The manual only mentions the 4wd model like 4 times in the whole thing though.
- Sun Jun 06, 2010 5:33 pm
#198883
thats sweet
91 s10 (sold)
91 s10 (sold)
- Thu Jul 08, 2010 1:16 am
#203602
I have spend a lot of time in the junkyard studying the underside of the crv trying to decide if i could get the real time 4wd offf of that and onto my eg8. I thing that the rear trailing arms would line up but other than that idk how much work it would be to mount the rear diff and the transfer case and all that sutff
- Wed Jul 14, 2010 3:47 pm
#204573
First I will admit I read Super Street often lol. The July 2010 issue has a F20C and is a fully functional RWD drift 93 VTI (EG4). It is pretty sweet to say the least. The photos are very limited on sideways rolling shots however it does feature a lot of pics of the chassis set up. The re routed the exhaust because they used the tunnel where the exhaust normally runs for the driveshaft. I am betting the rear differential would pose some serious issues but I know it is possible. On this particular car they converted the front suspension to a S13's. They fabricated a hybrid S2K / 180SX drive shaft to make it possible for the Honda trans to be one with the R200 Nissan rear end featuring a NISMO LSD! This allows them to incorporate the S13 rear components as well. With the rear diff in place there wasn't enough room for the gas tank which had to be moved up into the spare tire well. The builder claims in Japan the conversion cost him around 2200.00!! No way that could be done for that little in the states unless you got the hook up LOL. This car has gained a lot of popularity in Japan and there are others makin their way thorugh this swap. Oh yeah it reads this took them like 2 months to get this far
I will agree that is one hacked up monstrosity of a HONDA/NISSAN. Still Bad Ass!
- Wed Jul 14, 2010 5:56 pm
#204605
As far as the CR-V trans there is a RWD Prelude in the July 2010 Honda Issue of Super Street. This Prelude utilizes a H2B Adapter plate to mate the CR-V trans to the H22A. This leads me to believe that a B Series motor should be able to match right up with the AWD CR-V trans? In the case of this project car they had to use custom motor mounts to raise the H22 3" to fit the trans causing the need for a custom hood as well. The drive shaft is again ran down the exhaust tunnel. In this case they used Flat 3" tubing for the re-routed exhaust for better ground clearance. they also had to relocate the gas tank in the spare tire well. It dosn't say what type of rear end they use. However, it does say that the builder used a gearset that was developed in 1979 by concept ford racing. This probably gives the much needed strenght and gearing required to allow for the turbo charged H22A power to work with this setup. It doesn't say what type of drive shaft either, but to have an AWD EG there will undoubtedly require many custom fabricated parts. Is anyone familiar with the functionality of the CR-V trans and if it could serve the racing purpose I am sure we would all be interested in?
