thicker rad better than the stock thiner rad?
PostPosted: Sat Jul 16, 2011 6:13 am
by optimuslc
my stock thin rad gets cloged every now and then. sit significantly better to swap for a thicker rad? 2 row better than 1?
PostPosted: Sat Jul 16, 2011 10:57 am
by eggman95
I'm no expert ,but I would say yes just make sure it's a good brand.
PostPosted: Sat Jul 16, 2011 12:24 pm
by Chance
Agreed^ its better...as long as its not a cheapo!!
PostPosted: Sun Jul 17, 2011 11:21 pm
by nvturbo
When you add coolant and water into the radiator, make sure the water is filtered, not tap water. Some tap water have solvents that can build up, thus clogging it. If you want a decent aluminum radiator, get Mishimoto. For a tad more, you can opt for a Koyo. I had both on separate cars....can't really tell the difference except for the price.
PostPosted: Mon Jul 18, 2011 12:55 am
by JUICE
or at equal quality to the mishimoto, get the Neukin setup i got. just as good, cheaper, and 100% plug-n-play out of the box.
my review on it.. http://civic-eg.com/viewtopic.php?t=18342
got a 2 core rad!
PostPosted: Mon Jul 18, 2011 1:08 am
by optimuslc
got 1 from japan surplus, i think its from an HRV, i think it will fit snug. its from an automatic car so i hope theres no conversion needed. will update soon. :)
PostPosted: Mon Jul 18, 2011 3:00 am
by elrompetoto
That's not normal 4 it 2 clog so much
using just water in your rad
PostPosted: Sun Jul 24, 2011 10:29 am
by optimuslc
can i use just plain filtered water with no coolant in my rad?
Re: using just water in your rad
PostPosted: Sun Jul 24, 2011 12:58 pm
by RWMIII
optimuslc wrote:can i use just plain filtered water with no coolant in my rad?
if you mean distilled, then yes.
