- Sat Nov 03, 2012 3:39 pm
#319127
Start you car...I'm sure you can get it jump started.
Now with the engine running
what volts are showing with no accesories on?
what volts are showing with all accesories on (AC/Heater on high, headlights on, radio on, rear defroster on, and domelight on) ?
Your can test the voltages at the battery or other places.
^This test will show if your alternator is working correctly
Now before you do that test check your grounding points in your engine bay. If they are corroded, clean them. This will cause voltage drop and will not charge the battery correctly
After you test the alternator if you want to find out if something is draining your battery...you need to do a parastic draw test.
http://www.youtube.com/watch?v=PYUoXApI89Q
http://www.youtube.com/watch?v=KF1gijj03_0
94' civic si
JDM B16A w/AC
My daily driver:
http://tiny.cc/3bdut
K3 GSXR 1000:
http://tinyurl.com/3u6obdx
