- Sat Jan 05, 2013 12:36 am
#323313
i have a 92 honda civic dx sedan and about 2 weeks ago it had trouble starting. the car would just crank and crank but not start. 1 out of 3 tries the car would eventually start. i realized that the fuel pump was only priming on occasion as well. i was driving home from school one day and i turned a corner and the car just ended up dying on me. i tried to start it after it died out, but no anvil just crank. i pushed my car back to the house and re soldered the main relay. every time i turn my key into second position it primes which is not the problem anymore. the car still wont start just crank. i changed the spark plugs, cleaned out distributor cap, restarted ecu, charged the battery and still don't have a start. i am now lost as to what i should do. i need to car for school, but i guess in the meantime ill take the bus. any suggestions would help! thanks!
- Sat Jan 05, 2013 2:05 am
#323318
well pull one of the plugs leave it hooked to the plug wire and set it on the valve cover. Have a friend turn her over and check for spark. If your getting spark then check to see if you have fuel. My guess is you have a fuel issue.
- Sat Jan 05, 2013 2:24 am
#323321
when it is cranking, do you get any sputter at all like it wants to try to start?
- Sat Jan 05, 2013 2:43 am
#323325
i just filled up my tank full of gas as well. if it was a fuel issue how would i go about checking for the problem? and i will check the spark tomorrow morning as its very cold and dark now.
<br><br>
the cranking just keeps cranking and cranking, i feel like its wants to start but i am not too positive on this.
p.s thanks for the quick reply guys! means a lot
<br><br>
- Sat Jan 05, 2013 5:38 am
#323331
94' civic si
JDM B16A w/AC
JDM B16A w/AC
