Cleaning my airconditioning unit
Thu Nov 13, 2014 11:08 pm
by silverEG8
Hi civic-EG,
I been wanting to clean my sedan's airconditioning unit. I already removed the glove compartment removed the clips and screws, but just couldn't figure out what to do next LOL.
Hope y'all can help me out. Thanks.
Thu Nov 13, 2014 11:14 pm
by Leppy
look under the dash board below the glove box, there is a cylinder shaped panel with a connector going to it and three screws holding it up. Unscrew those, pull the connector off, and you'll have access to the blower.
Clean all the debris out of there and make sure the bearings are good, also make sure there isn't any trash blocking the vents and such under there.
Fri Nov 14, 2014 12:46 am
by silverEG8
Leppy wrote:look under the dash board below the glove box, there is a cylinder shaped panel with a connector going to it and three screws holding it up. Unscrew those, pull the connector off, and you'll have access to the blower.
Thanks Leppy. Will I need to open the evaporator as well?
