Worn front lca's / tie rods?
PostPosted: Sat Apr 04, 2015 5:31 pm
by 95LX_just_in
hvae brand new falken 195/50 tires on my 15x7's and the inside of the front tires are already beginning to wear quickly and im wondering if my destroyed bushings on the lca/s and shitty tie rods are the culprit. and if i should just buy some prothane bushings for $35 or controls dfor $75 any insight is appreciated thanks
PostPosted: Sat Apr 04, 2015 5:36 pm
by TrailerTrash
you need a front end alignment. the toe on your car is set too far out.
if you recently had an alignment then either lowered the car or did anything else suspension related, you need it aligned again.
PostPosted: Mon Apr 06, 2015 5:33 am
by Civic Savior
Either way i would invest in the poly bushings. They are relatively easy to install and are also fairly cheap :thumb:
PostPosted: Mon Apr 06, 2015 1:57 pm
by 95LX_just_in
thanks yall :D
