- Wed Sep 23, 2015 5:33 am
#356178
so i have a 92 civic sedan which i have stated on this forum before, but for some reason its not letting me post in it cause its locked.
teal suggested that it was my dizzy that caused the problem. because when i did the paperclip method to get check engine light codes it lights up code 4.
code four signifies crank position sensor. since my motor is a d15b7 motor the crank position sensor is in the dizzy. i replaced the dizzy and the problem still persists.
so heres the run down. when i start the car it has no check engine light being thrown. the only time the check engine light comes on is when i hit highway speeds for about 2 minutes the check engine light will come on then run like crap. i believe this is called limp mode.
when i step on the gas petal with the check engine light on it just backfires... and there is no power at all. however, the check engine light only comes on sometimes. which drives me crazy!! not all the time!
can anyone give me an insight on where to start please. i check all the fuses and they all seem to be fine.
