- Sun Aug 16, 2009 9:57 pm
#138198
Ok guys, so it's Sunday, already one week since I don't have a car. I checked my VSS sensor and I found out the screw that holds it in place with the trany is broken!! and there is a piece of screw blocking the hole so I cant screw it back :O what do I do now?
Here is pic of where the screw is stuck in the hole on the trany, is there a way to get that piece out?
I moved on to the TPS now, and the only thing I saw wrong with it, is that it wasn't making the right contact with the throttle and that there is 2 lines for my TPS.
Here is a pic of the 2 sockets that fit on my TPS, the green one is that one that has been on it, the other one in red just hangs around. Is this normal?
After I did all these I took the car for a spin, and as usual, everything was ok until my car got warmed up. Then my check engine light came back on and my car started acting up. I drove it back to the parking spot and read my CEL again. Now it only shows me code 4 which is my CKP <.< the other 2 codes didnt showed up this time.
Now I'm pretty sure I need to change my CKP which is inside my Distributor. I want to know if my Disctrbutor is a OBD1 or OBD2 before I buy it. How can I find out? I just know my engine is a B16a2 but I don't know from what car or year they got it...... will it make a difference if I buy the wrong one?
Here is a pic of my current distributor for refference ^^ / Oh and btw, do you see that oil on my radiator hose? That is coming from the botton of my distributor <.<
Thanks again guys.
Thanks again guys.
I couldn't have said it better myself...
