- Tue May 24, 2011 5:10 pm
#256592
Ive done this to many cars without problems, only results. I do half a can through the intake mani, and a full can at the gas station with an empty tank then fill up AFTER pouring seafoam in. It does wonders for a rough idle or hesitation and it can help some with response also.
- Tue May 24, 2011 5:48 pm
#256601
i am very curious to do this myself. I'll have to do my research.
- Fri Jul 01, 2011 8:18 am
#261819
ive heard that if you seafoam and you have any cracks or leaks in your engine you could remove build up that was (in a weird way) helping your car by coving the cracks and having it removed would definately help with emmissons but maybe reveal other isuses.... any one knw if that is true...
i would like to try it also but at the same time worried if itll cause problems by removing build up[/quote]
***SoCal Civic***
**Ride OR Die**
**Ride OR Die**
- Sat Jul 02, 2011 6:43 am
#261949
well i finally Seafoamed. put 1/3 in gas [full tank] and 1/3 in vacum tube coonected to intake [brake vacum hose line]. let the car sit for 10 minutes and then started up. took a good 10 seconds of cracking for the engine to finally fire, then as stated, burned white smoke for about 5 minutes, alot of smoke. i did it on a not so common truck road. I then drove home about 10 minutes away. seemed to help a little, nothing dramatic. if anything my idle is more steady.
- Sat Mar 02, 2013 3:23 am
#327566
When putting 1/3 into the brake booster, does it go into the line to the brake booster or the one towards the manifold? I've been putting it into the line that goes to the booster, I hope nothing bad happens haha
- Sat Mar 02, 2013 5:32 pm
#327584
I've done this on a variety of cars that I have owned. And you are right. I had blown valve seals but i guess the prior owner neglected them for so long (I dont quite know how you can miss that) That enough carbon built up and the problem "went away" until you remove the carbon that is.
In the long run its a smart move. If can show you where problems are in your car that may not be major but can surely lead to major problems.
cleenEX_93 wrote:ive heard that if you seafoam and you have any cracks or leaks in your engine you could remove build up that was (in a weird way) helping your car by coving the cracks and having it removed would definately help with emmissons but maybe reveal other isuses.... any one knw if that is true...[/quote]
- Sat Mar 02, 2013 11:22 pm
#327591
i dont like to put this in my oil.....this is why
your bearings and seals build up a coating or film over time to help protect them. the sea foam eats that away.
not good for the oil imo. but in the vac line and gas i do that on my high milage cars. but never on anything under 100k.
do it at your own risk.
1995 4 door civic b18c jrsc
