- Wed Dec 16, 2009 12:19 am
#162108
yes it will run wiothout it. but what the point of that. you have to wire up the v-tec to the ecu. or buy yourself a v-tec harness. witch if you bout a full swap it should come with the correct harness.
egsedanguy wrote:yes it will run wiothout it. but what the point of that. you have to wire up the v-tec to the ecu. or buy yourself a v-tec harness. witch if you bout a full swap it should come with the correct harness.OK , does a full swap mean it comes with the transmission as well... I don't think I need a transmission as the one I currently have is good.. or can I just get a full swap engine only ? The thing is they don't advertise them as a full swap so how should I know ?
1992 Honda Civic LX
