- Sat Jan 22, 2011 4:38 am
#234770
Whats up guys i hqve a b7/z6 mini me and i want to squeeze more power. I have i/he the head is stock, i was wondering if i PnP, mill the head (how much to mill?) gasket matching, and stage 2 cams with a base map on the mods that im going to do. I was wondering if i get the base map with all the mods that im going to do will it be safe to run on, On just a base map? And how much hp will i expect. I know if i get a tune i could get more gains. I want you guys opion And help on what to do...
- Sat Jan 22, 2011 5:15 am
#234775
There is a purpose for a Base Map. To be a base to tune on top of. Base Map's are not made to be daily driven on. Base Maps are made for one engine setup. The Engine is was based off of. If you decide to Run your car on a "Base Map" or even worse a "Performance Base map you that will give you more power even bone stock" Dont be surprised when you have major engine issues.
Just becouse a cam is "Stage 2" doesn't mean other brands will be the same. For example a Bisimoto Stage 2 cam will be different then a Skunk 2 stage 2 cam. Dont forget you will want to upgrade your springs and retainers.
Also none of us can guess how much horsepower you will make. Anything we post would be a guess. It depends on your elevation. How good your engine is running, how good(or if a base map, how bad) your Tune is.
