Page 1 of 2
Engine problem ?
PostPosted: Fri Feb 14, 2014 3:51 pm
by Phoenix288
Hi, my engine has been doing strange things lately.
Stopping the car at a red light or stop sign, the engine kept its rpms at around 1500 for 30 seconds before settling into idle at 700.
I was just wondering what it could be and if it could create problems in the future.
PostPosted: Fri Feb 14, 2014 4:33 pm
by silverEG8
Might have something to do with fluctuating fuel supply?
PostPosted: Fri Feb 14, 2014 4:37 pm
by Phoenix288
The only thing that comes to mind is that I recently went from 95 octane to 98 octane.
Or could the fuel pump be on its last legs ?
PostPosted: Fri Feb 14, 2014 5:04 pm
by silverEG8
My hunch would be on the octane level.
PostPosted: Fri Feb 14, 2014 5:05 pm
by Phoenix288
Ok thanks, so it is probably temporary. Thanks for the infos.
PostPosted: Fri Feb 14, 2014 5:10 pm
by silverEG8
welcome :D
PostPosted: Fri Feb 14, 2014 5:20 pm
by HeikDiesel
I highly doubt octane is causing this. I would look at items that affect idle: IAC,vacuum hoses, FITV, EGR, etc
PostPosted: Fri Feb 14, 2014 5:27 pm
by Phoenix288
Ok, I'll look into it. I've got an inspection planed for the 25th. I'll add it to the list.
PostPosted: Sat Feb 15, 2014 7:19 pm
by brandoff88
silver eg, why in the HELL would a change that small in octane cause an idle issue....no offense but that sounded like you made that up on the spot....lol
PostPosted: Sun Feb 16, 2014 2:34 pm
by silverEG8
Well, that was my hunch. If I'm wrong, I stand corrected. :D
PostPosted: Sun Feb 16, 2014 7:08 pm
by brandoff88
I meant no offense, but if he upgraded octane wouldn't his motor run better lol, but it definitely sounds like something maybe vacuum related, id double check all the hoses and stuff to make sure they are not brittle and cracked
PostPosted: Sun Feb 16, 2014 7:41 pm
by Phoenix288
It runs awesome ! It just need 30 seconds to get to idle after I disengage the clutch and let go of the throttle.
PostPosted: Sun Feb 16, 2014 10:10 pm
by brandoff88
have you adjusted your idle screw yet? could be set high, and is it fully warmed up when this happens? I know mine likes to idle around 1100 until warmed up and at lights it will kinda idle high then go down until warm...
PostPosted: Sun Feb 16, 2014 10:19 pm
by Phoenix288
To answer your first question, I have not touched the idle screw. Since I don't know where it is coming from and the event is temporary, I'd rather not change anything.
For your second question, it usually happens when the engine is cold. My commute is about 15 minutes so the engine would be warmed up.
As for my driving behavior during the commute, I shift up at max 4000 RPM.
That's all the information I can come up with, if you'd like to know more specifics, you can ask.
PostPosted: Tue Feb 18, 2014 7:39 pm
by suspendedHatch
brandoff88 wrote:I meant no offense, but if he upgraded octane wouldn't his motor run better lol
You call him out on that and then unleash this little morsel lol
Higher octane doesn't make your car run better. If your engine doesn't require it, it technically makes it run worse. Higher octane is harder to burn.
