radiator
PostPosted: Wed Oct 08, 2008 11:42 pm
by tigerafro
why is it important to get an aluminum radiator?
mine is cracked right now and i have a cai. does it matter if i get an oem?
PostPosted: Thu Oct 09, 2008 12:02 am
by KRYSTED9354
A aftermarket will cool your car ALOT better, way better cooling motor runs better.
and looks nice !!
PostPosted: Thu Oct 09, 2008 3:05 am
by sdots
Aftermarket means better cooling and generally the fins are made of a better material than the OEM. An aluminum has a better life span and aids the cooling of your coolant better in contrast to OEM. Colder coolant = better engine performance = better efficiency
PostPosted: Thu Oct 09, 2008 10:47 am
by biretsu89
cooler is always better :thumb:
PostPosted: Thu Oct 09, 2008 12:19 pm
by CivicTypeR
Ignore these fools. Go OEM ITR :thumb:
PostPosted: Thu Oct 09, 2008 2:40 pm
by tigerafro
what does itr stand for and where do i get one?
PostPosted: Fri Oct 10, 2008 7:55 am
by Macster
tigerafro wrote:what does itr stand for and where do i get one?
a radiator out of a Integra Type R. its probly easier to find a aftermarket aluminum one instead. i just have a half size oem that works fine but seeing as you need to replace it might as well go with something nice.
PostPosted: Sat Oct 11, 2008 3:32 am
by tigerafro
damn it. i bought a normal one replacement i think. its a four seasons i think? i don't rememeber.
PostPosted: Mon Nov 24, 2008 3:39 am
by terqtie
is it ok to remove the thermostat?
im living in hotter climates..
PostPosted: Tue Nov 25, 2008 1:08 am
by suspendedHatch
No it's not, and there's no benefit to doing so.
