By ikon
#79708 been workin alot on the car and once i replaced all that needed to be fixed the car ran great :woot: but on the test drive it died and now it wont stay running unless i give it gas otherwise it just dies out. any suggestions?
By biretsu89
#79714 how did the car run before? What did you replace when you fixed the car?
What gear and how high of rpms was your car at when it died while driving?
By ikon
#79731 before i replaced everything like shit. once i finished it ran great for like two days and once i replaced the throttlebody gasket it runs better but when i let the car idle it dies. i replaced ignition wires, spark plugs, distributor, fuel filter, IM gasket, pcv vavle, fuel injectors, and i already cleaned the iacv too. it first died when i was coming to a stop at a stop sign.
By marvinp8700
#79733 check your ignition coil
i had that prob on my integra and it was the coil
By ikon
#79736 i replaced the distributor so the coil is new
By marvinp8700
#79737 reading owned me
By mooze
#79746 any smoke from the tail?
By sdots
#79757 Check all your ground wires. Especially the one on your distributor.
#79785 Base ignition timing and set the IACV according to the procedure in the manual.
By biretsu89
#79814 check your fuel pump? my pump is starting to go... for some reason it doesnt want to turn on when its hot? haha...O.o
By ikon
#79830 i replaced the fuel pump a little while back so it should be good. but i dont know how to set the iacv cuz i dont have a manual. is it easy? and there is a little white smoke but i hope its not my head gasket. :( any help guys is appreciated im out of ideas and the car is almost there.
By biretsu89
#79836 white smoke? O.o... I forgot... .. umm... check your coolant.... does it look normal... or is the color a little dark?...
By Faded_Milano
#79842 check your idle speed control screw. It might be too far in and not letting in enough air when the throttle is closed to keep the engine running.
By mooze
#79892 welll thats how mine started. are you about due for an oil change?
By biretsu89
#79921 Lets hope its the idle screw... ifs its a blown head... aye....
