high flow catalytic converter
PostPosted: Wed Nov 26, 2008 7:34 pm
by eg4
I was thinking of buying a high flow cat converter but I am not sure if it will increase hp or not? and if yes by how much? will it be a good add on to my EG? any feedback.
PostPosted: Sun Nov 30, 2008 12:50 am
by trustdestruction
You'll gain like 2HP MAX, not much. It is a worthwhile mod however, because your cat is old and probably pretty clogged up, causing a decrease in power and fuel economy. Getting a new catalytic converter should help to restore fuel economy and give you a couple more HP.
PostPosted: Sun Nov 30, 2008 12:53 am
by zeppelin101
As above you'll get 1 horsepower if you're lucky, not worth it as a power mod but certainly a fresh cat will help with everything else
PostPosted: Sun Nov 30, 2008 8:59 pm
by suspendedHatch
Waste of money unless you're boosted. In that case, you'd want a larger diameter converter.
I'd call 2hp very optimistic. I don't think you'll see enough of a difference to be conclusive. Horsepower can vary by a couple hp from one pull to the next.
PostPosted: Mon Dec 01, 2008 9:01 pm
by eg4
This is a cat that I was planning to buy http://www.jdmshit.com/RacingCat/
For me it only seems that it will be a straight pipe from the manifold till the silencer.
PostPosted: Mon Dec 01, 2008 9:10 pm
by biretsu89
OooO... so you not lookin for a catalytic converter for emissions.. you just want to straight pipe it :lol: .. It will make your exhaust sound like ass :thumb: ... but why not? they are pretty cheap and easy to install
PostPosted: Tue Dec 02, 2008 12:56 am
by trustdestruction
please don't get one of those
they make your exhaust sound like crap (raspy), gain next to no HP over a high-flow cat, and at the same time greatly increase emission of the poisonous gas Carbon Monoxide
EDIT: also, they rust, no matter how much stainless steel the seller "claims" they're made of
How do I know all of this, and that you don't want one? I had one.
PostPosted: Tue Dec 02, 2008 4:08 pm
by -paul
trustdestruction wrote:please don't get one of those
Yep, mine's currently got a straight through on it and it sounds like a pile of crap, after I've sorted my head gasket, that's the next thing on my list - to buy a catalyst converter and a decent back box!
PostPosted: Wed Dec 03, 2008 5:44 pm
by eg4
even on a 1.5 SOHC Vtec will sound like crap?
PostPosted: Wed Dec 03, 2008 5:53 pm
by marvinp8700
eg4 wrote:even on a 1.5 SOHC Vtec will sound like crap?
yes got the set up on my 1.6 sohc v-tec
sounds god awful
PostPosted: Wed Dec 03, 2008 8:57 pm
by eg4
sounds god awful
any increase in your bhp?
PostPosted: Wed Dec 03, 2008 11:32 pm
by zeppelin101
Unless you're running a big turbo and have serious piping running through the whole car a high-flow cat will always be a better choice over a de-cat.
A tuning magazine did a test not so long back and the gains with both were poor, but the high-flow proved the better choice - better 'gain', and obviously better for the environment...
PostPosted: Thu Dec 04, 2008 6:11 am
by trustdestruction
zeppelin101 wrote:A tuning magazine did a test not so long back and the gains with both were poor, but the high-flow proved the better choice - better 'gain', and obviously better for the environment...
http://www.importtuner.com/features/061 ... index.html
You gain like 1HP over a high-flow cat by using a test pipe. It's not worth the damage it does.
