Removing Cylinder head, stuck with Intake manifold
As some of you may know, I mentioned that my head gasket had been leaking and that I was in the middle of replacing it. That was like 2weeks ago but I've been busy. Anyway, here's where I'm at with replacing the head gasket.
Before I started
Where I'm at now
I've aligned it to top dead centre, with the "Up" mark on the Cam at the top. I've used a little bit of white paint to mark the belt and the Cam itself so I know exactly where it's going back. Just haven't taken it off yet.
Removed everything else necessary, including cylinder head bolts and exhaust manifold bolts etc except for the intake manifold. With the situation/environment I'm working in, it'll be better to leave the intake manifold attached to the head and lift it off with it then unbolt it after.
As I've never done this before, my problem is I'm scared to fuck with the fuel hoses. You can see which hoses I've pulled off so far (pics at the top), and I've pulled off several electrical connectors, but when I tried unbolting one of the fuel hoses (marked in red, look at picture below), fuel started to leak out from the bolt as I was loosening it, so I quickly re-tightened.
I need to get this done asap cause I need the car drivable by Monday, Tuesday the latest. So I need that head off, replace gaskets and whatever else necessary, possibly get the head skimmed too if it's warped.
So what do I do? Is this normal? Will I have any other trouble with the other hoses? Am to expect fuel gushing everywhere? As I say, this is my first time doing it, I just need to expect the unexpected.
Thanks!
Paul
Before I started
Where I'm at now
Thanks!
Paul
