- Sun Feb 01, 2009 6:44 am
#93597
might have a leak from your fuel sending unit, its located under your back seat.
take out your back seat and remove the access cover and check for a leak there
- Sun Feb 01, 2009 9:32 pm
#93667
Nope. It's a clogged charcoal canister. They're like $30 new from the dealer last I checked. You'll get rid of that smell and pick up 3 mpg. Not to mention you'll end global warming, but nobody cares, right?
- Mon Feb 02, 2009 4:51 am
#93739
x2 thats what I was thinking too
suspendedHatch wrote:Nope. It's a clogged charcoal canister. They're like $30 new from the dealer last I checked. You'll get rid of that smell and pick up 3 mpg. Not to mention you'll end global warming, but nobody cares, right?
JUICE wrote:Race cars are like boats I guess. Time to bust out another thousand.
- Tue Feb 03, 2009 4:31 pm
#93967
i would also check your PCV, it would be the valve that releases presure from the cannister into your intake manifold.. bad valve would seem the same as cologged cannister
Fuck rehab, boost is NOT an addiction, its a lifestyle.
Nah, who am i kidding I'm addicted.
- Tue Feb 03, 2009 11:36 pm
#94032
The PCV is in no way connected to the charcoal canister. Are you referring to the purge control solenoid?
The charcoal canister is to the side and below your battery on the firewall. It's a black plastic cylinder with three hoses coming off it.
When you turn off your car, you still have pressurized fuel in the lines. These are captured by the charcoal canister and stored until you drive your car again. Then they're released into your intake manifold to be burned. Saves you some gas and reduces the amount of hydrocarbons that go into the atmosphere that are causing the north pole to melt, california to go into the worst drought in recorded history, and great britain to get buried in snow.
- Sun Mar 01, 2009 9:24 pm
#99721
what if your car doesnt have a charcoal canister,mine was just hanging in by a hose everything was capped and unplugged so i just ripped it out because it was slamming against my firewall everytime i hit a bump,and i didnt have a gas smell ,well i did but it was from the rusted fuel line going up to my fuel pump,it started out just making the line wet,then one day i hit a monster pothole and it broke the line ,i would check your lines
- Mon Mar 02, 2009 12:51 am
#99787
It wouldn't be a problem if your car was designed w/out an evap system like the JDM cars or the newer dead-head fuel systems. But basically it means your engine has no way to relieve the residual fuel pressure.
