more problems.(fack)
ok so i finally get my blow by problem fixed with my catch can:D, then i found my boost leak:D now i had a problem with idle...so i cleaned both the IACV and the FITV--i think thats what its called, i adjusted the screw inside and it fixed my idle surge.
now after a bit of driving around town i come to a red light, the idle will drop to like nothing, the oil light will dimm on and off and then stay on then if i let it sit it will stall on me....but this was happening before i cleaned any of the valves..
my oil pressure at idle(500rpm) is about 10psi and at 3000rpm is 25psi
any ideas of whats going on ?
