My EG having fuel problems??
Sat Apr 25, 2009 3:40 am
by CRAZY_EG
So I just bought this 94 civic eg with a B18B swap out and it just started giving me problems. When I start going its like it wants to die on me like its not getting gas so I give it some gas and it hesitates for a few then it grabs like the line opens up or something. I've switched out the fuel filter and I've cleaned out the fuel injection port I have a new fuel pump but havn't swapped it out yet I was wondering if that was really the problem or not because if its not I need to fix the problem before it gets to bad and hurts my engine. Hit me up thanks for the help.
Sat Apr 25, 2009 3:50 am
by JUICE
check your plugs/wiring??? tune up??
Sat Apr 25, 2009 4:12 am
by rflindy89
I had a similar problem about two years ago when I had a Nissan 200SX and I thought it wasn't getting fuel and it turned out to be the AC Conpressor was locking up. I took it off and got a belt sized so I ran with no A/C and I never had a problem after that.
Just throwing that out there just incase its not a Fuel issue.
Good Luck
Thu May 07, 2009 5:48 pm
by BLaCkSiLo
i don't know if it's related at all, but i just had this problem with my z6, i put an adjustable FPR on there and a fuel pressure gauge, it was stumbling hard in low RPM, but up above 3k, it was like nothing was wrong, after checking all the timing and resistance in the wires, the cap, everything, it was just the spark plugs....so check those out, easy fix
