new problem
PostPosted: Tue Jun 02, 2009 2:47 pm
by eg-95
hey all im new to the world of eg civic and honda's in general but last nite when i was on my way home i accelerated and my car died.. not to an extent where it cut out but it was chucking like mad and had no power but on high revs it smoothed itself out.. and it idled ok..
i got it a good bit home and at a cross roads it died.. i waited a few mins and then started it up again and it was grand.. but then when i reved it it started spittin and jumpin again..
i reved it hard in first gear and then changed to second gear and tehn it was ok?
im stumped for a solution to theis problem..
im thinkin its a fuel filter? any ideas?
any help is greatly appreciated as i need this car for gettin me to work and around.. unless i take the motorbike but that has no tax lol
PostPosted: Tue Jun 02, 2009 3:44 pm
by Dippin_EG
It could be the main relay, something in the distributor(cap/rotor/igniter), maybe spark plug wires, or the ignition timing could possibly be off.
Just throwing some things out there. :D
PostPosted: Tue Jun 02, 2009 3:46 pm
by Dippin_EG
it may also have something to do with the TPS or IACV
PostPosted: Tue Jun 02, 2009 4:04 pm
by drago742gtr
yea could be the tps mine studders a lil bit then at high revs it feels fine try checkin it out
PostPosted: Wed Jun 03, 2009 12:00 am
by eg-95
cheers guys... i dnt wanna appear like a complete idiot but what is tps and iacv.. im new to civics.. cvh ford engines ar my thing ha
by eg-95
PostPosted: Sat Jun 06, 2009 11:01 pm
by eg-95
ok i have this sorted now.. had a few problems.. ie bad plugs.. leaky seal..
fauty fuel pump and bad airfilter.. so i done a massive service and bobs ur uncle she alive again
thanks for all ur help guys
PostPosted: Sat Jun 06, 2009 11:48 pm
by Dippin_EG
:thumb:
PostPosted: Tue Jan 05, 2010 9:48 am
by kamikaza
i have similar problem. i was driving and car just died, and gauges droped...i stop and started motor again and it worked like nothing was happen...that's it...i think it's igniter unit or igniter coil...any opinions? advices?
PostPosted: Sat Jan 09, 2010 11:25 am
by Jack
kamikaza wrote:i have similar problem. i was driving and car just died, and gauges droped...i stop and started motor again and it worked like nothing was happen...that's it...i think it's igniter unit or igniter coil...any opinions? advices?
if all geuges drop then it's not the igniter unit or coil. if the igniter unit or coil will be damaged than the gauges would not drop. check your key mechanism. that power los in IG1 position might be caused by flying key in the mechanism. try to lubricate it and check all connections to it. or if you have an immo - go to the specialist for diagnosis. the immo would cause this problem too.
Regards from Poland :)
