- Mon Aug 06, 2012 5:08 am
#312899
Hey guys, so I have a 92 sedan and I knew the original owner hit something with the car but evidently it was quite a bit harder than I thought. I saw the blemish on the bumper and how the drivers side drooped a little but I thought it was mostly cosmetic. Well the other day I was underneath installing a new A/C compressor(had the under panel off)and noticed that the drivers side lower engine mount is being pulled away from the engine by the frame(the inside rubber is pulled out about an inch or so). You can see where the lower frame that the mount bolts to is bent outwards. The engine has a little bit of 'rock' to it during take off but its not very bad and I don't notice it all the time.
Does anybody have any suggestions for an easy/cheap way to get this fixed? This is just my beater car so I'm not looking to spend a ton of money but I would like things to be functioning correctly. I've heard of some very 'redneck' ways of frame straightening but I'm not sure any of them would work in my case. I also thought of making a bracket to relocate the engine mount slightly in order for it to line up and then of course I would buy a new mount.
Also, both my axles are bad(split boots)and the passengers side it much worse than the drivers(severe clicking even while accelerating in a straight line). I've always heard its pointless to replace axles on a front wheel drive car if you're having motor mount issues because it accelerates wear on the axles. Does anyone think this will apply in my case or should I just go ahead and swap out the axles?
Sorry, that was kinda long lol I really appreciate any advice anyone has to offer.
Thanks
-Rob
Thanks
-Rob
