Revs Dropping to Below 500rpm Sometimes Stalling
It's 50/50 if it does it but sometimes when I stop the revs drop to below 500 it idles, then it will either stay there, stall or if I give it a pump of the pedal it sometimes goes back up, sometimes it drops right back down and stalls.
I've cleaned the IACV and FITV, changed the plugs and leads, can't find a vacuum leak anywhere, alternator is charging at 14.5 volts.
I just had the bonnet up while it was idling around 450 gave it a rev by the throttle body, I could hear the filter sucking in air but the revs didn't rise?
any ideas?
any ideas?
