By Tugboat
#231206 Ok so long story short i changed my brake lights will not light up the fuse is fine and a new brake switch was put in but no dice anyone know what the fuck is wrong with this god damned car?
By Tugboat
#231217
ceelx wrote:maybe bulbs :hehe:
yeah i tested some not that
By ceelx
#231240 Maybe fault is in electric cluster
:roll:
By Tugboat
#231286 yeah its wiring or has to be something along the lines of that i gave up and am getting it fixed at the end of the week
By LaosToaster
#231948 maybe ur connections are corroded, clean them up real quick, and are u sure ur bulbs are dual-filament isntead of single filament?
By dawg316
#232014 grab a volt meter, get a friend to press the brake pedal and check if your getting voltage ( 12volts i belive). if you are then most likley have a bulb or ground problem. if you dont have voltage then you have a problem with the circuit. either break in wire or faulty brake switch ( even though you have a new one :S ) good luck with solving it. I hate cars some times, but its awsome when there working perfectly :woot:
By Tugboat
#232015 too late now i raged and the guy who sold it to me is trying to fix it xD, also its hard to work in like -20C weather in the dark xD
