- Fri Jan 13, 2012 2:19 am
#289720
I have been trying to fix this for some time now. Im to the point where I dont know what else to try. Here is whats happening:
The car will run just fine with no overheating when the thermostat is out. It will also heat up like normal.
With the thermostat in though, the car will over heat within 15 mines of driving. When I pop the hood the radiator is super hot on top and if you feel the bottom of it you can hold you hand on it because it is cold like the car was never on.
So I thought it was the radiator so i got a new one and put it in and it has had the same problem. So next i got a new thermostat and put it in (The right way) and it still did the same thing. So i checked to see if i had a blown head gasket by looking at the oil and coolent and there both just fine.
I did bleed the cooling system of all air so its not an air pocket.
I also it has a new water pump, But it is an ebay one so idk if that could be the problem or not.
So if you have any idea what this could be let me know cuz i have ran out of things to check.
JDM D15B VTEC
JDM D15B VTEC
thanks though.
