- Sun Sep 16, 2012 2:42 am
#315760
Car: 94 Civic Si
-Problem: When cranking engine its seems slower than normal and the speedometer needle moves as high as 100mph
-Brand new battery
-Batt voltage: 12.63
-Volts tested while cranking: 8.90
-Volts tested at Blk/Wht wire disconnected from starter cut relay when in start position:12.5 (Yellow arrow in pic)
-Parastic drain test: 15 milliamps
-Electrical add on: 2 way paging alarm
-If my car sits for more than 12 hours the car will not crank at all. Batt volts will be under 11.6
-Hypothesis: I'm thinking there is a short between the Blk/Red wire after the starter relay cut and the starter solenoid. (Red arrows in pic)
I did the test when I hot wired the starter solenoid directly from the battery and the motor cranked normal. When I use the key to crank it will seem slower than normal.
Is there a easier way to find a short without taking a lot of things out?
If you got any questions just ask
-Brand new battery
94' civic si
JDM B16A w/AC
JDM B16A w/AC
