came across one got to find it though i put a ek cluster into my eg you have to rewire the whole back end and stuff and it definately helps in time if you mark the harness on the cluster your putting in and attatching your connector peices as well 1st before ou even cut the first wire behind your cluster.
well didnt even have to edit this one i did a quick search on yahoo found this on honda tech this is the same diagram and stuff i used on my car to put a ek cluster into my eg
http://www.honda-tech.com/zerothread?id=1053318
