By drifterx808
#64642 I saw all the topics covering the converting a p/s rack to a manual rack by looping to lines together and adding a breather/reservoir to the third port. My question is, which 2 lines do you loop together?
From what I can see on my EX, there is the pressure hose that comes directly from the p/s pump, and there is 2 lines attached to the rack right next to each other,and both come from the reservoir. Is it these two lines that should be looped together? And than make the pressure line into the breather line? Or am I way off?
#64667 I think....remember i said " I THINK" you loop the two lines that go to and from the resivoir and put the breather or fluid tank on the one from the PS pump. But Im not sure and also need to know this.
By drifterx808
#64684 I just found this how-to over at jdmuniversecom.
Although it's converting a GSR rack, looks like the EG rack should be the same,or like it.
