By KRYSTED9354
#69338 OK, i will paypal 5$, { not much but better then nothing} to the person that send me a link or DIY on how to remove a Honda Del Sol passenger air bag, i have no clue how to remove, do i have to take out dashboard ? anywhere any help would be great, and 5$ if someone find this hard to find DIY , thanks again :thumb:
#69339 take out the glovebox and there are bolts you can get to under inside the dash that hold the airbag in from the bottom.
Of course, disconnect the battery & srs before you remove
By KRYSTED9354
#69343 yeah teal, but there 4 screws holding the airbag and there's NO way getting to them, i took out the glove box, and only go to the bracket screws, the ones holding the air bag 4 screws, on each side there's no way getting to them, ?
#69345 hmm, do you have some extensions & a universal joint? Or maybe you have to take the dash off? I've only removed the pass bag on EK's and it was easier to get to the bolts.
By KRYSTED9354
#69346 yeah, i tries a snake driver, which is a Long bendable wrench, and still can't, Maybe i have to take off dash, Which i was hopping Not to LoL.
By asianrob
#69347 it should be just those 2 10mm in front and 2 10 mm in the back get a long extension and go at it.
