- Mon Oct 24, 2011 4:10 am
#278825
it I'd a b18b1 block bored .20 over eagle knife edged crank acl race bearing arp rod bolts eagle h beam rods srp 10:5:1 comp pistons gsr oil pump water pump gsr head cometic head gasket arp head bolts gsr head with port and polish jg valves jg springs jg retainers Brian crower stage 2 cams skunk2 intake aem fuel rail 440 injectors blox 68 mm throttle body full msd ignition 7lb flywheel stage3 clutch b16 trans I think that's it may be more I'm gonna have it tuned at a local shop how much hp would u estimate to the wheels
"If you want your car to be cheap and fast it wont be reliable... If you want your car to be reliable and cheap it wont be fast... If you want your car to be fast and reliable it wont be cheap"
